86 dB |
Small size rooms: >25 watts Medium size rooms: >65 watts Large size rooms: >125 watts |
200 watts |
6 ohms |
3.9 - 10 ohms |
3.8 - 9.2 ohms |
-31¡Æ - +22¡Æ |
-5¡Æ - +28¡Æ |
8.7 ohms |
46 Hz - 23 kHz |
49 Hz |
17 litres |
25.1 lbs (11.4 kg) |
Dimensions (W x H x L): |
22.5" x 6.5" x 12.6" (570 x 165 x 320 mm) |
2 way, impedance corrected |
2000 Hz |
Woofers 6 dB/oct; Tweeter 12 dB/oct |
Gold binding posts |
Above or below TV-set or on a stand |
Tweeter: 28 mm soft dome. Magnetic fluid. Pure aluminium wire voice coil. Rear chamber.
Woofers: 2 x 15 cm polypropylene cone. 75 mm pure aluminium wire voice coil.
Cabinet: Front baffle 22 mm MDF. Port plugs included. Magnetic shielded. Bitumen damped enclosure. |
