87 dB |
Medium size rooms: >50 watts Large size rooms: >100 watts |
300 watts |
4 ohms |
3.9 - 20 ohms |
4.1 - 8.0 ohms |
-61¡Æ - +20¡Æ |
-8.8¡Æ - +23¡Æ |
6.5 ohms |
26 Hz - 21 kHz |
24 Hz |
51 litres |
55 lbs (27.1 kg) |
Dimensions (W x H x L): |
8.8" x 41.6" x 14.3" (222 x 1057 x 363 mm) |
3 way, impedance corrected |
430 and 2000 Hz |
Woofer 6 dB/oct; Midrange 6 & 12 dB/oct; Tweeter 12 dB/oct |
Gold binding posts |
Floor |
Tweeter: 28 mm soft dome. Magnetic fluid. Pure aluminium wire voice coil. Rear chamber.
Midrange: 15 cm with die cast basket 38 mm pure aluminium wire voice coil. Cone and dustcap moulded as one piece
Woofers: 2 x 20 cm polypropylene cone 75 mm pure aluminium wire voice coil.
Cabinet: Front baffle 28 mm MDF. Port plugs and spikes included. Bitumen damped enclosure. |
