Á¦Ç°½ºÆå(Specification)
90 dB |
300 Watts RMS (4 Ohm) |
4 Ohm |
Bass Principal: |
Reflex |
88 lbs (40 kg) |
Dimensions (W x H x D): |
8.8" / 16.5" x 61" x 17.5" (224 / 420 x 1550 x 445 mm) |
6 dB/oct |
CE-comp. WBT gold biding posts |
Tweeter: |
28 mm soft dome, magnetic fluid, 6 mm aluminium-alloy front, with high heat-dissipation, integrated in baffle, pure aluminium wire voice pure aluminium wire voice coil, aluminium-alloy rear chamber with high heat chamber with high heat dissipation, large neodymium magnet rings |
Woofer: |
Woofer/Midranges: 17cm, one-piece moulded MSP-cone, 75mm pure aluminum wire voice coil. |
Separate chamber for network, glassfiber-reinforced PCB with extra copper-thickness, capacitors with low loss dielectricum, zero compression resistors. |
Cabinet: |
Cabinets made of highdamping MDF sandwich, front baffle made of 40/16 mm HDF sandwich, adjustable feet with internal spikes. |
¾ÈÁ¤°¨ ÀÖ´Â »ç¿îµå°¡ ÀåÁ¡, ¾ÚÇÁÀÇ ¼±ÅÃÀÌ Áß¿äÇÏ´Ù.
º»Áö ÇÊÀÚÀ̽š¹±³¼ö´Ô¿¡°Ô¼, ´ÙÀοÀµð¿À ½ºÇÇÄ¿ °¡¿îµ¥ ÀûÀýÇÑ ½Ã½ºÅÛÀÌ ÀÖÀ¸¸é Çϳª ¼Ò°³ÇØ ´Þ¶ó´Â ÀüÈ°¡ ¿Ô´Ù. ÀºÅðÇϽŠÀº»ç´Ô²² µå¸®·Á ÇÑ´Ù¸é¼ ´ÙÀÎ ¿Àµð¿À ½ºÇÇÄ¿¸¦ Á¦ÀÏ ¸¹ÀÌ ½ÃûÇßÀ¸´Ï ±ÇÇÒ ¸¸ÇÑ Á¦Ç°À» ½±°Ô ¼±ÅÃÇÒ ¼ö ÀÖÁö ¾Ê°Ú´À³Ä´Â °ÍÀ̾ú´Ù. ±×·¯°íº¸´Ï ³»°Ô ´ÙÀοÀµð¿ÀÀÇ ½ºÇÇÄ¿´Â ¾î´À Á¦Ç°º¸´Ù °¡Àå ¸¹ÀÌ °ÅÃÄ°£ °Í °°´Ù.
À̹ø¿¡ ½ÃûÇÏ´Â Á¦Ç° Áß¿¡µµ ¿ª½Ã ´ÙÀοÀµð¿À ½ºÆÛÄ¿´Â Æ÷ÇԵǾî ÀÖ¾ú´Ù. 51È£¿¡¼ ½ÃûÇß´ø ÄÁÇÇ´ø½º C4ÀÇ ¹Ù·Î ¹ØÀÇ µ¿»ýÀÎ ÄÁÇÇ´ø½º 7ÀÌ´Ù. ÀÌ ¿ª½Ã ÄÁÇÇ´ø½º C4¿Í °°Àº µðÀÚÀÎÀÌÁö¸¸ 2¿þÀÌ 4½ºÇÇÄ¿·Î Çüº¸´Ù´Â ÈξÀ ½ÉÇÃÇÑ ¼³°è´Ù.
Àß·èÇÑ ¿©ÀÎÀÇ Ç㸮¼±Ã³·³ °î¼±À» ±×¸®´Â 4crn µÎ²²ÀÇ MDF ¹èÇÃÀº ÀÎŬ·ÎÀú¿Í µ¶¸³µÇ¾î ÀÖÀ¸¸ç, ¿ÏÃæÀ縦 »çÀÌ¿¡ µÎ°í ¹ÝŸ¿øÇüÀÇ À¯¼±Çü À¯ÀúÆÇÀ¸·Î ÀÎŬ·ÎÀúÀÇ ¾ç¿·¸éÀ» ²ø¾î¾È°í ÀÖ´Ù. ÀÌ ¼³°è´Â ¹èÇðú ÀÎŬ·ÎÀú »óÈ£°£ÀÇ Áøµ¿À» ¹èÁ¦Çϱâ À§ÇÑ °ÍÀ¸·Î Àç»ýµÇ´Â À½À» ±ú²ýÇÏ°Ô Çϱâ À§Çؼ´Ù.
ä¿ëµÈ À¯´ÖÀº 17cm ±¸°æÀÇ ¿ìÆÛ°¡ ¸ÇÀ§¿Í ¸Ç¹Ø¿¡ °¢°¢ 1°³¾¿ ÀåÂøµÇ¾úÀ¸¸ç,°¡¿îµ¥ À§Ä¡ÇÑ 2°³ÀÇ Æ®À§Åʹ Ư¼ö ó¸®µÈ ¾Ë·ç¹Ì´½ÆÇ¿¡ ä¿ëµÇ¾ú´Ù. Àü¿¡µµ ¾ð±ÞÇßµíÀÌ ½ÅÇüÀÇ ¿¡¼ÒŸ Æ®À§ÅÍ´Â °·ÂÇÑ ³×¿Àµð´½ ¸¶±×³Ý°ú ¾Ë·ç¹Ì´½ º¸À̽ºÄÚÀÏ,±×¸®°í ½ÇÅ© µ¼ Ç¥¸é¿¡ Ư¼öÄÚÆà 󸮷Π¿¹ÀüÀÇ ¿¡¼ÒŸº¸´Ù ÈξÀ ºÎµå·¯¿î °í¿ªÀ» ½ÇÇöÇßÀ¸¸ç Çã¿ëÀԷµµ ´ëÆø Çâ»óµÇ¾ú´Ù.
Ư±âÇÒ »çÇ×Àº ÀÏÁ÷¼±»ó¿¡ À§Ä¡ÇÑ À¯´ÖÀÌ Æò¹üÇÑ º´·Ä ¿¬°áÀÌ ¾Æ´Ñ DDC(Dynaudio Direct-ivity Control)¶ó´Â ½Å±â¼úÀÌ Ã¤¿ëµÇ¾ú´Ù´Â °ÍÀÌ´Ù. ÀÌ ±â¼úÀº À§¾Æ·¡ À¯´Ö »óÈ£°£ ÁöÇ⼺À» ÄÁÆ®·ÑÇÏ¿© ¹Ù´Ú¸é°ú õÁ¤ÀÇ ¹Ý»çÆĸ¦ 75%±îÁö Á¦¾îÇÏ´Â µ¥ ¼º°øÇß´Ù°íÇÑ´Ù.
Çü¿¡ ºñÇØ ¾ÈÁ¤µÈ ¸ð½ÀÀº »ç¿îµå¿¡¼µµ ¹Ý¿µµÈ µí, ´ÜÁ¤Çϸ鼵µ ¾ÈÁ¤°¨ ÀÖ´Â À½À» ½ÇÇöÇÑ´Ù. À½Àå°¨°ú Áß¿ªÀÇ Ç³¸¸ÇÔ¿¡¼´Â Çü°ú´Â Á¶±Ý ´Ù¸£Áö¸¸ ź·ÂÀûÀ̸ç Á¤°¥ÇÑ Àú¿ªÀº ÁÖº¯ ȯ°æÀÌ ±ò²ûÇÏ¸ç ½ºÇǵðÇÔ°ú ÇÔ²² ¶Ç·ÇÇÑ À½»óÀº ÆÄÆ®µéÀÇ À§Ä¡¸¦ º¸¿© ÁÖ´Â µíÇÏ´Ù. ÇǾƳëÀÇ ¾îÅÃÀ½Àº ¸í¡ÇÏ°í ÀÜÇâ ¶ÇÇÑ ±âºÐÀÌ ÁÁ´Ù. °³¼±µÈ ¿¡¼ÒŸÀÇ ´öÅÃÀÎ µí »þÇÁÇϸ鼵µ À±±âÀÖ´Â ¹ÙÀ̿ø°ÀÇ °í¿ª 󸮰¡ ¸Å²ô·´´Ù. ¾Ç±âµéÀÇ Áú°¨µµ È®½ÇÇÏÁö¸¸ ÀúÀ½ÀÇ À½Á¤ ¶ÇÇѶǷÇÇÏ´Ù. ¾ÚÇÁ¸¸ Àß ¸¸³´Ù¸é À帣¿¡ °ü°è¾øÀÌ ÁÁÀº À½À¸·Î À½¾Ç¸¸À» Æí¾ÈÇÏ°Ô µéÀ» ¼ö ÀÖÀ» °Í °°Àº ½Ã½ºÅÛÀÌ´Ù. (³ªº´¿í)
½Ã¾ß°¡ Ź Æ®ÀÎ µíÇÑ ¸ÀÀÌ ÁÁ¾Æ. ÇÏÀÌ¿£µåÀÇ ÀÚÁúÀ» °®Ãá ½ºÇÇÄ¿
À̹ø ÇÏÀÌÆÄÀÌ ¼î¿¡¼ Àλó ±í°Ô µé¾ú´ø ¸ðµ¨ ÁßÀÇ Çϳª°¡ ¹Ù·Î º» Á¦Ç°ÀÌ´Ù. À½À» µé¾îº¸¸é, ±âÁ¸ÀÇ ½ÉÁö°¡ ±½°í, µðÅ×ÀÏÀÌ ºÐ¸íÇϸç,°íÀ½¿¡¼ ÀúÀ½¿¡ À̸£´Â ÆòźÇÑ ÀçÇö·ÂÀº º¯ÇÔÀÌ ¾øÁö¸¸, ¾îµòÁö ¸ð¸£°Ô ½Ã¾ß°¡ Ź Æ®ÀÎ µíÇÑ ¸ÀÀÌ ¸Å¿ì ÁÁ´Ù. ¸»ÇÏÀÚ¸é Àü¸ÁÀÌ ´õ¿í ÁÁ¾ÆÁö°í, À½µµ ½Ã¿ø½Ã¿øÇØ Á³´Ù°í ³ª ÇÒ±î? ¾ÚÇÁ¸¦ ¹Ù²Ü ¶§¸¶´Ù ±× ¼º°Ý°ú ½Ç·ÂÀ» ºÐ¸íÇÏ°Ô ¹Ý¿µÇÏ´Â ´ë¸ñ¿¡¼´Â ¿ª½Ã ÇÏÀÌ¿£µå¶ó´Â »ý°¢À» µé°Ô ÇÑ´Ù.
¿¹¸¦ µé¾î, Á¦´ÏÆÛ ¿ø½º°¡ ºÎ¸¥ 'ÆäÀ̸ӽº ºí·ç ·¹ÀÎÄÚÆ®¡¯ ¸¦ µéÀ¸¸é, º¹ÀâÇÏ°Ô Ã³¸®µÈ ¾Ç±â±ºÀÌ Á¿ì·Î È® ÆîÃÄÁø °¡¿îµ¥, µÎÅùÇÑ À°ÁúÀ» °®Ãá ±×³àÀÇ ¸ñ¼Ò¸®°¡ ÇÑ°¡¿îµ¥¿¡ Á¤À§ÇÑ´Ù. ¹ßÀ½µµ ¸í·áÇÏ°í ¸ñ¼Ò¸®ÀÇ °¾àµµ ¸íÈ®ÇÏ´Ù.
·¹ÀÌ ºê¶ó¿î°ú Å©¸®½ºÂù ¸Æºê¶óÀ̵尡 2´ëÀÇ ´õºí º£À̽º·Î ¹ø°¥¾Æ ÄÞÇΰú ¼Ö·Î¸¦ ¹Ýº¹ÇÏ´Â ½´ÆÛ º£À̽º µð½ºÅ©´Â, ±× ±î´Ù·Î¿î Àú¿ª Àç»ý¿¡ ÀÖ¾î¼ ÇϳªÀÇ ·¹ÆÛ·±½º°¡ µÇ°í Àִµ¥, ÀÌ ´ë¸ñµµ ¹«³È÷ Åë°úÇß´Ù. ½ÉÁö¾î ±½Àº º£À̽º ÁÙÀÌ Ç÷§À» Ä¡¸é¼ Âô ¿ï¸®´Â ¼Ò¸®±îÁö ÀÚ¿¬½º·´°Ô Æ÷ÂøÇÑ´Ù.
¹æÇâÀ» ¹Ù²ã, ¸»·¯ÀÇ ±³Çâ°î Á¦5¹øÀ» ¼ÖƼ ¿¬ÁÖ·Î µè´Â´Ù. óÀ½ ¿ÞÂÊ ½ºÇÇÄ¿¿¡¼ ³¶¶ûÇÏ°Ô Æ®·³ÆêÀÌ Å׸¶¸¦ ºÒ´Ù°¡, ¼¼È÷ Ç® »çÀÌÁî ¿ÀÄɽºÆ®¶óÀÇ ÅõƼ·Î ÇâÇÏ´Â ÀÏ·ÃÀÇ °úÁ¤ÀÌ ¸Å¿ì µå¶ó¸¶Æ½ÇÏ°Ô Àü°³µÈ´Ù. ±×·³¿¡µµ ±Í°¡ µû°©°Å³ª ½Å°æÀÌ °Å½½¸®Áö ¾Ê´Â´Ù. ±â¿ÕÀÌ¸é ½Í¾î¼, ·ÏÀ̳ª ºí·ç½º µî ²öÀû²öÀûÇÑ À½¾Çµéµµ °É¾îº¸Áö¸¸,Ưº°È÷ °¡¸®´Â °Í °°Áö ¾Ê´Ù. (ÀÌÁ¾ÇÐ)
