Á¦Ç°½ºÆå(Specification)
92 dB |
400 Watts RMS (4 Ohm) |
4 Ohm |
Bass Principal: |
Reflex |
110 lbs (50 kg) |
Dimensions (W x H x D): |
9.8" / 16.5" x 69.0" x 17.5" (250 / 420 x 1750 x 445 mm) |
6 dB/oct |
CE-comp. WBT gold biding posts |
Tweeter: |
28 mm soft dome, magnetic fluid, 6 mm aluminium-alloy front, with high heat-dissipation, integrated in baffle, pure aluminium wire voice pure aluminium wire voice coil, aluminium-alloy rear chamber with high heat chamber with high heat dissipation, large neodymium magnet rings |
Midrange: |
15 cm, one-piece moulded MSP-cone, 38 mm pure aluminium wire voice coil. |
Woofer: |
20 cm, one-piece moulded MSP-cone, 75 mm pure aluminium wire voice coil. |
Separate chamber for network, glassfiber-reinforced PCB with extra copper-thickness, capacitors with low loss dielectricum, zero compression resistors. |
Cabinet: |
Cabinets made of highdamping MDF sandwich, front baffle made of 40/16 mm HDF sandwich, adjustable feet with internal spikes. |
20¼¼±â¸» ÀáÀáÈ÷ ¹¯Çô ÇÏÀÌ¿£µå ¾÷ü¿¡°Ô À¯´ÖÀ» °ø±ÞÇÏ´ø ´ÙÀοÀµð¿À°¡ ¾î¸¶¾î¸¶ÇÑ °¡°ÝÀÇ ½ºÇÇÄ¿¸¦ ¸¸µé¾î ³»¾ú´Ù. 10³â °¡±îÀÌ Áö³ Áö±Ý±îÁöµµ ±× ÀÚ¸®¸¦ À¯ÁöÇÏ°í ÀÖ´Â ¿¡ºñ´ø½º ¸¶½ºÅÍ. °ðÀ̾î ÁÖ´Ï¾î ¸ðµ¨ÀÎ ÅÛÅ×ÀÌ¼Ç ÀÌ Ãâ½ÃµÇ¾ú´Ù. ¶á±Ý¾øÀÌ ÀÌÀü±îÁö »ç½Ç»óÀÇ Ç÷¡±×½ÊÀÌ´ø ÄÁÇÇ´ø½º 5¿¡ ºñÇØ ¾öû ºñ½Ñ °í°¡¸¦ ¹ßÇ¥ÇØ ³õ°í ÇÑ ´Ü°è¾¿ ¹ØÀ¸·Î »õ Á¦Ç°À» ³»º¸³Â´Ù. ÄÁÇÇ´ø½º ½Ã¸®Áî´Â ÀÌÀüÀÇ ³×¸ð³ ¹Ú½º¿Í ¿Ö ±×·¯ÇÏ¿´´ÂÁö ÃßÃøÀÌ ³¹«ÇÑ Æ®À§ÅÍ°¡ ¹ØÀ¸·Î °¡ ÀÖ´Â ±¸Á¶¸¦ ¹ö¸®°í »õ·Ó°Ô ¼±À» º¸¿´ ´Ù. ¹Ù²ï ÄÁÇÇ´ø½º´Â °íÀ½°ú ÀúÀ½ÀÌ µÎ¦¾¿ µé¾î°¡ »óÇÏ ´ëĪÀ» ÀÌ·ç´Â À̸¥¹Ù °¡»ó µ¿ÃàÇü ½ºÅ¸ÀÏÀÇ ¿¡ºñ´ø½ºÀÇ ¹æ½Ä¿¡ µû¶ú´Ù. ±¸°æÀÌÀÛÀº ¿ìÆÛ¸¦ ÅëÇØ ´õ ºü¸¥ ¹ÝÀÀÀ» ¾ò°íÀÚ Çß°í, À¯´ÖÀº ¿¡ºñ´ø½º¿¡¼ ¼±º¸ÀÎ °î¸é ¶óÀÎÀ» °Á¶ÇÏ´Â ¹èÇÿ¡ ´Þ¾Æ ³õ¾Ò´Ù. ÀÌ°°ÀÌ »õ·Î¿î ÄÁÇÇ´ø½º´Â ÀÌÀüÀÇ ½Ã¸®Áî¿Í °øÅëÁ¡Àº º°¹Ý ¾ø´Ù. Á¤È®È÷ ¸»ÇØ °³·®¸ðµ¨ÀÌ ¾Æ´Ï¶ó ¿¡ºñ´ø½ºÀÇ ÁÖ´Ï¾î ¸ðµ¨·Î º¸¾Æ¾ß µÈ´Ù. ¿ÜÇü°ú ±¸¼º»Ó ¾Æ´Ï¶ó ´Þ¶óÁøÁ¡Àº ¶Ç ÀÖ´Ù. ¿À´Ã³¯ÀÇ ´ÙÀοÀµð¿À¸¦ ¸¸µé¾î ³»´Â ÀÏµî °ø½ÅÀÌ´ø ¿¡¼ÒŸ°¡ 2¹ø° ¹öÀüÀ¸·Î °³·®µÇ¾ú´Ù. Àü¼³ÀÇ º¸°Ë¿¡ ¼ÕÀ»´í °Í. °ÅÀÇ Â÷ÀÌ´Â ¾ø¾î º¸ÀÌÁö¸¸, ÀÌÀüº¸´Ù ÈξÀ ¿Àµð¿ÀÀûÀΠƯ¼ºÀ¸·Î °³¼±µÇ¾ú´Ù. Ç×»ó ÇÑ ¹ß¦¾¿ ¾Õ¼°¬´ø ½ºÄµ ½ºÇÈÀÇ °³·®Çüº¸´Ù ÃÖ±Ù ¹Ð¸®´Â ÆǼ¼°¡ µÇ¾ú´Ù. ±×°Ô ¾Æ´Ï¶ó°í Ç×ÀÇÇÒÁöµµ ¸ð¸£Áö¸¸, ÀÌÀü ¿¡¼ÒŸ¸¦ ÀÌ¿ëÇÏ´ø ÇÏÀÌ¿£µå ¾÷üÀÌ´ø ¼Ò´©½º Æĺ£¸£°¡ ½ºÄµ½ºÇÈÀ¸·Î, À̱۽ºÅÏ¿÷½ºÀÇ ¾Èµå¶ó°¡ ¹®µµ·ÎÇÁÀÇ AMT·Î ¶°³ª°¬´Ù. »õ·Î ³ª¿Â ÄÁÇÇ´ø½º´Â ¾Æ¹«Æ° ÀÌ °³·®Çü ¿¡¼ÒŸÀÎ ¿¡¼ÒŸ2¸¦ ´Þ°í ³ª¿Ô´Ù.
»ç½Ç ¿À´Ã ¼Ò°³ÇÒ C4´Â °èȹ´ë·Î¶ó¸é ÄÁÇÇ´ø½º ½Ã¸®ÁîÀÇ ÃÖ»óÀ§ ¸ðµ¨Àº ¾Æ´Ò°ÍÀÌ´Ù. C7À̶ó´Â ´ëÇü±â°¡ °èȹµÇ¾î ÀÖ¾ú´Ù. C4ÀÇ Àú¿ª ¿ìÆÛ¸¦ ´ë±¸°æȽÃŲ ¸ðµ¨À̾ú´Âµ¥ ¾Æ¸¶ ±×¸®µÇ¸é ±¸µ¿»ó ³Á¡µµ ÀÖÀ» Å×°í, ¸ð¾çµµ Á» ÀÌ»óÇØ º¸¿´°í, ¿¡ºñ´ø½º ÅÛÅ×À̼ǰú ¾îÁ¤ÂÄÇÑ À§Ä¡°¡ µÈ Å¿ÀÌ ¾Æ´Ò±î? ÃÊ¹Ý ÄÁÇÇ´ø½º ºê·Î½´¾î¿¡ º¸ÀÌ´ø ÀÌ ¸ðµ¨Àº ¼ö³âÀÌ Áö³ªµµ·Ï Ãâ½ÃµÇÁö ¾Ê°í ÀÖÀ¸´Ï ¾ÕÀ¸·Îµµ ³ª¿Ã ÀÏÀº ¾ø¾î º¸ÀδÙ. ±×·³ ¿©±â±îÁö ÄÁÇÇ´ø½ºÀÇ ¼Ò°³´Â ¸¶Ä¡µµ·Ï ÇÏ°í ³ª¿Â Áö Á¦¹ýµÈ ÀÌ ½ºÇÇÄ¿°¡ ¿Ö ²ÙÁØÇÏ°Ô Àα⸦ °¡Áö °Ô µÇ¾ú´ÂÁö ³ª¸§´ë·Î ±× ÀÌÀ¯¸¦ ÇÑ ¹ø »ìÆ캸ÀÚ.
¿ì¼±Àº µðÀÚÀÎÀÌ´Ù. ÁÖ°Å°ø°£¿¡ ÁÖ¿äÀ§Ä¡¿¡ ÀÚ¸®ÇÏ°Ô µÉ ¿Àµð¿ÀÀÎ ¸¸Å µðÀÚÀÎÀÌ Áß¿ä½Ã µÈ´Ù. ¾Æ¹«¸® ¿Àµð¿À ¸¶´Ï¾Æ¶ó ÇÏ¿©µµ µÚÁÖ °°Àº °ÍÀ» ³öµÎ±â´Â Á» ±×·¯ÇÏ´Ù. ÁÖ¸ñÀûÀÌ À½¾ÇÀ» µè´Â °ÍÀ̱⿡ µðÀÚÀÎÀÌ »©¾î³¯ ÇÊ¿ä´Â ¾øÁö¸¸, ÇÊ¿äÇÑ ÃÖ¼ÒÀÇ ¹ÌÀû ¿äÀÎÀÌ ÀÖ¾î¾ßµÈ´Ù. C4¸¦ À§½ÃÇÑ ÄÁÇÇ´ø½º ½Ã¸®Áî´Â ´ÙÀοÀµð¿À Áß¿¡¼ ±×·¡µµ °¡Àå ÁÁÀº ¿Ü°üÀ» °¡Áö°í ÀÖ´Ù.
µÎ¹ø°·Î ¾ÈÁ¤¼ºÀÌ´Ù. ½ºÅ׵𼿷¯¸¦ º¸¸é ¿ì¼± ¸ðµ¨ÀÇ º¯È°¡ ÀæÁö ¾Ê´Ù. ¹Ý¸é Á¤¸» ºñ¾ç½ÉÀûÀ̶ó ÇÒ ¸¸Å ÀÚÁÖ ¸ðµ¨À» ¹Ù²Ù´Â ¾÷ü°¡ ¸¹ÀÌ ÀÖ´Ù. ÇÊÀÚ´Â ±¹³» ÀÚµ¿Â÷ ¾÷ü¸¸ÀÇ À̾߱âÀÎÁÙ ¾Ë¾Ò´Âµ¥ ÇØ¿Ü ¿Àµð¿À ¾÷üµéµµ ³»³» º°¼ö ¾ø´Â °Í °°´Ù. ¸ðµ¨¸í µÚ¿¡ ABC ¾ËÆĺªÀ» ºÙ¿©°¡¸é¼, ¹øÈ£¸¦ Á¶±Ý¾¿ ¹Ù²Ù¸é¼ ¸ÅÇØ º¯ÇüÇ°À» ³»³õ´Âµ¥ ½Å·Ú°¡ °¡Áö ¾Ê´Â´Ù. ±×·¸°Ô ¼öÂ÷ °³·®ÇÑ´Ù¸é ´ëü ÃʱâÀÛÀº ´ëÃæ ¸¸µé¾î ³õÀº Á¦Ç°Àΰ¡? ´ÙÀοÀµð¿À, ±× Áß¿¡¼ ƯÈ÷ ÄÁÇÇ´ø½º´Â ´Ü ÇÑÂ÷·ÊÀÇ º¯°æµµ ¾øÀÌ »ý»êÇØ ³»°í ÀÖ¾î ´õ¿í ½Å·Ú°¡ °£´Ù. ±×¸®°í Ç×»ó Àû´çÇÑ Áß°í °¡°ÝÀ» À¯ÁöÇÏ´Â µÎÅÍ¿î ¼ö¿äÃþÀÌ Àֱ⿡ ¾ÈÁ¤ÀûÀÌ´Ù. ´ÜÁö C4¸¸ÀÇ ¸»ÀÌ ¾Æ´Ñ ÀÌÀüÀÇ C5ÀÇ Áß°í°¡°ÝÀ» º¸¾Æµµ ¾ÈÁ¤¼ºÀ» °¡Áø´Ù.
¼¼ ¹ø° ÇÕ¸®ÀûÀÎ °¡°Ý°ú ºê·£µå ÆÄ¿ö°¡ ÀÖ´Ù. ¿Àµð¿À´Â ´©°¡ ¹¹¶ó Çصµ, ƯÈ÷ ÇÏÀÌ¿£µåÀÇ °æ¿ì »çÄ¡Ç°ÀÌ´Ù. ¸¶À½ÀÇ ¾ç½ÄÀÌ´Ï »ýÇÊÇ°À̶ó´À´Ï ¹äÀº ¸ø ¸Ô¾îµµ À½¾ÇÀº µé¾î¾ßÇÑ´Ù´Ï ÇÏ´Â ¼Ò¸®´Â Á¤¸» ¹èºÎ ¸¥ ¼Ò¸®ÀÌ´Ù. ¸ðµç »çÄ¡Ç°ÀÌ ±×·¯Çϵí Àû´çÇÑ ºê·£µå¿¡ Àû´çÇÏ°Ô ºñ½Ñ °¡°Ý´ë¿¡ À§Ä¡ÇÑ °ÍÀÌ ¹Ù·Î C4ÀÌ´Ù. Å©¸é Å©°í, ÀûÀ¸¸é Àû´Ù°íµµ ÇÒ ¼ö ÀÖ´Â Áß¼ÒÇüÂ÷ ÇÑ´ë °ª. ±×¸®°í ´ÙÀοÀµð¿À¶ó´Â ¾Ë ¸¸ÇÑ »ç¶÷ ¸ðµÎ ´Ù ¾Æ´Â, ±×¸®°í Á¦¹ý ´ëÇü±â·ÎÀÇ ¸é¸ð°¡ ÀÖ´Â, ±×·¡¼ C4´Â ±¸¸ÅÀÚÀÇ Ç㿵½É°ú °æÁ¦¼ºÀ» µ¿½Ã¿¡ ¸¸Á·½ÃÅ°´Â Á¢Á¡¿¡ ÀÖ´Ù.
ÀÌ ¼¼ °¡Áö ÀÌ¿Ü¿¡µµ °¡Àå Áß¿äÇÑ ¿ä¼Ò´Â, ¾Æ´Ï ÀÌ ¼¼ °¡Áö¸¦ °¡´ÉÇÏ°Ô ¸¸µç °¡Àå Áß¿äÇÑ °ÍÀº µû·Î ÀÖ´Ù. »ç½Ç ½ºÇÇÄ¿¸¦ ÃßõÇÒ ¶§ ´ÙÀοÀµð¿À´Â Àû´çÈ÷ À¯¸íÇÏ°í °¡°Ýµµ Àû´çÇÏ°í ±×·¡¼ ¾ÈÁ¤ÀûÀ¸·Î ¼±ÅÃÇÒ ¼ö ÀÖ´Â, ÃëÇâ¿¡ »ó°ü¾øÀÌ °¡Àå ¹«³ÇÑ ½ºÇÇÄ¿À̱â´Â ÇÏ´Ù. ¸Å·ÂÀûÀÎ ¿ä¼Ò, È® Àâ¾Æ²ô´Â Ä«¸®½º¸¶°¡ ¾Æ´Ñ ¾ÈÁ¤ÀûÀÎ ¼±ÅÃÀ̶ó ¿ä¾àÇÒ ¼ö ÀÖÁö¸¸, ±× ¾ÈÁ¤ÀûÀÎ À§Ä¡°¡ µÇ±â±îÁö °¡Àå Áß¿äÇÑ °ÍÀº ¹Ù·Î ¸¸µé¾î³»´Â ¼Ò¸®ÀÇ Áú(òõ)ÀÌ ÀÖ¾î¾ß °¡´ÉÇÑ ÀÏÀ̾ú´Ù. ´ç¿¬È÷ C4´Â °ú°Å ÄÁÇÇ´ø½º¿¡ ºñÇØ ¹°¸®Àû Ư¼ºÀÌ ÁÁ¾ÆÁ³´Ù(¹°·Ð °¡°Ýµµ ¿ùµîÈ÷ ¿Ã¶ó°¬´Ù). ÁÖ·ù¿¡ µû¶ó »ö°¨ÀÌ Çö´ëÀûÀ¸·Î ¹Ù²î¾î ÀÌÀüÀÇ ÁøÇÑ ¸ÀÀÌ ¿¶¾îÁø°¨µµ ºÎÀÎÇÒ ¼ö ¾øÁö¸¸, ¿äÁîÀ½¿¡ ³ª¿À´Â ½ºÇÇÄ¿·Î´Â Àΰ£¹Ì°¡ ÀÖ´Ù. ±×¸®°í C5°¡ °¡Áö´ø ±¸µ¿ÀÇ ³Á¡µµ ´ëºÎºÐ ÇؼҰ¡ µÇ¾ú´Ù. ±¸µ¿ÀÌ ½¬¿öÁ® ¾çÁúÀÇ KT88 Ǫ½ÃÇ®ÀÌ¸é ¾Æ¹« ¹®Á¦¾øÀÌ Æ÷±ÙÇÏ°Ô Á¸ ÄÝÆ®·¹ÀÎÀ» ¿ï¸± ¼öµµ ÀÖ°í, TR¾ÚÇÁ ¿ª½Ã ±»ÀÌ ´ëÃâ·ÂÀ̳ª Àú ÀÓÇÇ´ø½º¸¦ ¿äÇÏÁö ¾Ê°í FIM SACDÀÇ Çö´ëÀû À½»öÀ» ¾òÀ» ¼öµµ ÀÖ´Ù. ±×·¡¼ µüÈ÷ ¸ÅĪÀÌ ¾È ¾î¿ï·È´ø ¾ÚÇÁ´Â ¾øÀ» Á¤µµ·Î ¹ü¿ë¼ºÀÌ ÁÁ´Ù. ÀÌ °°Àº ¹ü¿ë¼ºÀº À½¾Ç¿¡¼µµ ±×·¯ÇÏ´Ù. ÀçÁîµµ ³ª»ÚÁö´Â ¾Ê°í Ŭ·¡½Äµµ °¡¸®Áö¸¦ ¾Ê´Â´Ù. ÇÏÀÌÆäÃ÷ÀÇ ¹ÙÀ̿ø° ¼ÒÇ°°ú °°Àº ¼ÒÆí¼ºÀÇ °æ¿ì ¼ÒÇü ½ºÇÇÄ¿ °°Àº ¼¼¹ÐÇÏ°í ¾Æ±âÀÚ±âÇÑ ¸é¸ðµµ º¸¿©ÁÖ°í, <ÅõƼ>¿Í °°Àº ¿ÀÄɽºÆ®¶óÀÇ ¼î ÄÉÀ̽º À½¹ÝÀÇ ´ëÆí¼º¿¡¼´Â µ¹º¯ÇÏ¿© ´ëÇü±â·ÎÀÇ ¿ï¸²µµ µé·ÁÁØ´Ù. ¹°·Ð C4 ¿ª½Ã ´ÙÀοÀµð¿À ƯÀ¯ÀÇ ¼ºÇâÀ» dz±ä´Ù. ÇÏÁö¸¸ ±× ÇâÀÌ ÁøÇÏ¿© ¸ðµÎ ´ÙÀοÀµð¿À ¼Ò¸®·Î ¸¸µå´Â µ¶¼±ÀûÀÎ ¸éÀº ¾ø´Ù. C4 ¸»°íµµ ¸Å·ÂÀûÀÎ ½ºÇÇÄ¿°¡ ÂüÀ¸·Î ¸¹ÀÌ ÀÖ´Ù. ´«¿¡ ½ï µé¾î¿À´Â ¿Ü°ü¿¡ ±Í¿¡ ÂøÂø °¨±â´Â ¸Å·ÂÀûÀÎ ¼Ò¸®¸¦ µé·ÁÁØ´Ù. ³ÃÁ¤ÇÏ°Ô ¸»ÇØ C4°¡ ±×·¯ÇÏÁö´Â ¾Ê´Ù. ÀÚ±ØÀûÀÎ °Íº¸´Ù Æí¾ÈÇÑ °ÍÀÌ ÁÁ°í, ¹º°¡ Çõ½Å ÀûÀ̱⺸´Ù º¸¼öÀûÀ¸·Î ¿î¿ëÇÏ°í ½Í°í, ÀæÀº ±³Ã¼º¸´Ù ÁøµæÀÌ ¿À·¡¾²°í ½Í°í, ±×Àú Æí¾ÈÈ÷ À½¾Ç¿¡ ºü Á® µé°í ½Í´Ù¸é À̸¸ÇÑ ½ºÇÇÄ¿µµ ¾ø´Ù. ¾ÈÁ¤ÀûÀÌ°í º¸¼öÀûÀÎ ±×·± »ç¶÷µéÀÌ ÁÁ¾ÆÇÏ´Â °Í °°´Ù. ¿Àµð ¿À¸¦ ¿±¤ÀûÀ¸·Î Çϱ⺸´Ù À½¾ÇÀÌ ÁÁÀº »ç¶÷µéÀÌ ´õ ÁÁ¾ÆÇÏ´Â °Í °°´Ù. ³ª´Â ±×·¡¼ ÁÁ´Ù. ¾Æ¹«¸® ¿Àµð ¿À°¡ ¿Á¤ÀûÀ¸·Î ÁÁ´Ù ÇÏ¿©µµ ±×°ÍÀÌ µé·ÁÁÖ´Â °ÍÀº °á±¹ À½¾ÇÀÌ´Ï ¸»ÀÌ´Ù. À̹ø ƯÁýÀº ½ºÅ׵𼿷¯ÀÌ´Ù. ¸¹Àº ÆǸŷ®À» ´Ü±â¿¡ ´Þ¼ºÇÑ º£½ºÆ®¼¿·¯³ª ¾öû³ ¹°·®°ú ±â¼ú·ÂÀÌ ÅõÀÔµÈ ±Ã±ØÀÇ ¿Àµð¿À ƯÁýÀÌ ¾Æ´Ï´Ù. Àº±ÙÇÏ°í Æ¢Áö ¾Ê´Â ¹ü¿ë¼ºÀ» °¡Áø ¿Àµð¿À, ±×·¡¼ ¸» ±×´ë·Î ½ºÅ׵𼿷¯·Î ´ÙÀοÀµð¿À C4´Â °¡Àå ÀûÇÕÇÑ ½ºÇÇÄ¿ÀÌ´Ù. ¿Á¤À¸·Î ´Ù°¡°¡±âº¸´Ù ¿À·¡ »ç±Í°Ô µÇ´Â ¼º°Ý ¹«´øÇÑ Ä£±¸¿Í °°Àº ½ºÇÇÄ¿ÀÌ´Ù.(±Û.½Å¿ìÁø) |
