Á¦Ç°½ºÆå(Specification)
86 dB |
Small size rooms: >30 watts Medium size rooms: >80 watts Large size rooms: -- watts |
160 watts |
4 ohms |
3.7 - 33.1 ohms |
3.8 - 9.3 ohms |
-53.9¡Æ - +30.4¡Æ |
-4.5¡Æ - +19.3¡Æ |
13.5 ohms |
41 Hz - 25 kHz |
46 Hz |
13 litres |
27.7 lbs. (12.6 kg) |
Dimensions (W x H x D): |
7.4¡± x 15.9¡± x 14.2¡± (188 x 404 x 360 mm) |
2 way. The crossover is impedance corrected |
1900 Hz |
6 dB/oct |
WBT Gold plated binding posts (for spades and 4 mm plugs) |
Dynaudio Stand2 |
Tweeter: 28 mm soft dome - technology from Esotar- Magnetic fluid. 5 mm machined aluminium front, with high heat-dissipation, integrated in baffle. Pure aluminium wire voice coil.
Woofer: Die-cast chassis. 17 cm one-piece moulded MSP polypropylene cone. 75 mm long throw pure aluminium wire voice coil, wound on Kapton Neodymium magnet ring.
Crossover: Thick glass fibre-reinforced PCB with extra copper thickness. Capacitors with low loss dielectricum. Zero compression resistors. Inductors wound on ¡°air cores¡±.
Cabinet: 20 mm MDF with internal MDF bracing and bituminous damping panels. Metal baffle sandwiched to the cabinet through a damping panel. Large 70 mm diameter vent with trumpet shape in both ends, vent plugs included. Available in different veneers, maple, cherry, rosewood, and black ash. Custom finishes upon request. Grille with magnetic lock system included. Spikes included. |
±Ý¼ÓÆÇ ¹èÇÃÀÇ Ã¤¿ëÀ¸·Î Åõ¸í¼ºÀÌ ¹è°¡µÈ »ç¿îµå
ÄÜÅõ¾î S½Ã¸®Áî´Â ´ÙÀοÀµð¿À°¡ AVÈ Ãß¼¼¶õ ½Ã´ëÀû È帧À» ¿°µÎ¿¡ µÎ°í °³¹ßÇÑ ¸ðµ¨±ºÀ¸·Î, º» ±â´Â ÀÌ ½Ã¸®ÁîÀÇ ¸·³» ¸ðµ¨ÀÌ´Ù. ÀÌ ½Ã¸®ÁîÀÇ »óÀ§ ¸ðµ¨ÀÎ S5.4³ª S3.4 µîÀº ¹°·Ð º»Áö¿¡ ÀÌ¹Ì ¼Ò°³µÈ ¹Ù ÀÖ´Â µ¥´Ù°¡, º» ±â¿Í´Â ¿©·¯ °¡Áö·Î Ư¼ºÀÌ ºñ½ÁÇÑ Á¦Ç°ÀÎ ÄÜÅõ¾î 1.3 SE¶õ Á¦Ç°µµ ÀÖÀ¸¹Ç·Î, ÀÌ ½ºÇÇÄ¿µéÀ» ½ÃûÇØ º» ¾ÖÈ£°¡¶ó¸é º» ±â¿¡ ´ëÇѼº´Éµµ ¹Ì·ç¾î ÁüÀÛÇÒ ¼ö ÀÖÀ» °ÍÀ¸·Î »ý°¢µÈ´Ù.
»ç½Ç ´ÙÀοÀµð¿ÀÀÇ ¶Ù¾î³ À½ÁúÀÇ ºñ°áÀº ¾Æ¸¶µµ µ¿»ç ƯÀ¯ÀÇ ³ëÇÏ¿ì°¡ ÅõÀÔµÈ º¸À̽º ÄÚÀÏ°ú ³×Æ®¿öÅ©¶§¹®ÀÏ °ÍÀÌ´Ù. º»±â ¿ª½Ã »ó±Þ ¸ðµ¨¿¡ ÅõÀÔµÈ À¯´ÖµéÀ» ±×´ë·Î ä¿ëÇÏ°í ÀÖ´Ù. ´Ù¸¸ Æ®À§ÅÍ¿Í ¹Ìµå·¹ÀÎÁö°¡ ÇÑ °³¾¿¸¸ ÀåÂøµÈ °ÍÀÌ ´Ù¸¦ »ÓÀÌ´Ù. ¶ÇÇÑ º»±â ¿ª½Ã ´Ù¸¥ ÄÜÅõ¾î ½Ã¸®Áî¿Í ¸¶Âù°¡Áö·Î ÀÎŬ·ÎÀúÀÇ ¹èÇÿ¡ 5mmÀÇ ¹«°Å¿î ±Ý¼ÓÆÇÀ» ä¿ëÇß´Ù´Â Á¡ÀÌ´Ù.
¸ÞÀÌÄ¿ÃøÀÇ ¼³¸íÀ¸·Î´Â MDF¿¡ ¹ÐÂø½ÃÅ°Áö ¾Ê°í °ø°£À» µÐ ä °íÁ¤½ÃŲ ÀÌ·± ±Ý¼ÓÆÇ ¹èÇÃÀº ¿ì¼± Åë¿ï¸²À» ÃÖ¼ÒÈÇÒ ¼ö ÀÖ´Ù´Â Á¡ÀÌ ÀåÁ¡À̶ó°í ÇÑ´Ù. ¶ÇÇÑ ´ëÇü º¸À̽ºÄÚÀÏ¿¡¼ ¹ß»ýµÇ´Â ¿À» ÇؼҽÃų ¼ö ÀÖ¾î¼ ¿À·£ ½Ã°£ µé¾îµµ À½ÁúÀÇ ¿È°¡ »ý±âÁö ¾Ê¾Æ, Åõ¸íÇÑ ¼Ò¸®¸¦ ¾òÀ» ¼ö ÀÖ´Ù°í ÇÑ´Ù.
½ÃûÇÑ ½ºÇÇÄ¿´Â ´Üdz³ª¹« ¹«´Ì¸ñÀ¸·Î ¸¶°¨ÇÑ °ÍÀ̾úÁö¸¸ Àå¹Ì³ª¹« ¹«´Ì¸ñÀ¸·Î ¸¶°¨ÇÑ Á¦Ç°µµ ÀÖ´Ù°í ÇÑ´Ù. ¹°·Ð ¿É¼ÇÀ¸·Î ´Ù¸¥ ¹«´Ì¸ñÀ¸·Î ¸¶°¨ÇÑ Á¦Çĵµ ¼±ÅÃÇÒ ¼ö ÀÖ´Ù. ºÏ¼¿ÇÁÇüÀ̱⠶§¹®¿¡ ½ºÅĵåÀÇ »ç¿ëÀº ÇʼöÀû. ¹°·Ð Àü¿ë ½ºÅĵ嵵 ÀÖÁö¸¸ º°µµ·Î ±¸ÀÔÇØ¾ß ÇÑ´Ù. º»±â¿¡ ¹ÂÁöÄà Çǵ¨¸®Æ¼ A308 CDÇ÷¹À̾î¿Í ¾ÚÇÁ·Î´Â º§ ÄÅäÀÇ ÇÁ¸®6+eVo 2 ¼¼Æ®¸¦ ¿¬°áÇؼ ¸î ÀåÀÇ CD¸¦ µé¾îº¸¾Ò´Ù.
¿ì¼± ¿äÁò ÈÁ¦°¡ µÇ°í ÀÖ´Â ±èÁ¤ÀÚÀÇ °¡¾ß±Ý Á¤¾Ç 'Çϴðú ¶¥, ±×¸®°í ¸í»ó' (C&L Music)ºÎÅÍ °É¾îº¸¾Ò´Ù. ¿ö³« ³ìÀ½ÀÌ ÁÁÀº Å¿ÀÎÁö °¡¾ß±Ý ÇöÀÇ ÈûÂù ¶³¸² µîÀÌ ¼Ò¸§ÀÌ ³¢Ä¥¸¸Å °í½º¶õÈ÷ ¹¯¾î³´Ù. »ç½Ç ÇÊÀÚ´Â ±¹¾Ç¿¡ ´ëÇؼ´Â ¹®¿ÜÇÑÀÌ¾î¼ °¡¾ß±Ý ¼Ò¸®ÀÇ Àü´Þ »óŸ¸À» üũÇߴµ¥, ¿ì¸®ÀÇ ÀüÅë ±â¾Ç ¿¬ÁÖÀÇ °æ¿ìµµ, ¿ª½Ã ÇÏÀÌ¿£µå ½Ã½ºÅÛÀ̶ó¾ß ±× ¾Æ¸§´Ù¿òÀÌ ±Ø´ëȵȴٴ ´À³¦À» ¹Þ¾Ò´Ù.
ÀÌ¾î¼ Å©´©Æ® ±ÍƲ·¯ÀÇ '¹Ì¶óŬ ÄÜÆ®¶óº£À̽º' (Camerata)¿¡¼´Â ÀúÀ½À» ¹Ð¾î³»´Â ÈûÀº »ó´ëÀûÀ¸·Î ¾àÇÏ°Ô ´À²¸Á³´Ù. ¼º¾ÇÀ¸·Î´Â Á¶¼ö¹ÌÀÇ '¿Â¸® ·¯ºê'(Erato), ´ëÆí¼ºÀ¸·Î´Â ·çºó½ºÅ¸ÀÎÀÇ º£Å亥 ÇǾƳë ÇùÁÖ°î Á¦5¹ø 'ȲÁ¦' (RCA), °í¿ªÀ» üũÇϱâ À§Çؼ µé¾îº» ¾È³×Á¶ÇÇ ¹«ÅÍÀÇ 'Ä«¸£¸à ÆÇŸÁö' (DG) µîÀÇ CD¸¦ °É¾î¼ È®ÀÎÇØ º» °á°ú, ´ÙÀοÀµð¿À ƯÀ¯ÀÇ Åõ¸í¼ºÀº ÃæºÐÈ÷ ÀÔÁõµÇ¾ú´Ù. (ÃÖÁ¤¹Î)
