Tweeter: Esotar2 - Magnetic fluid. 5 mm machined aluminium front, with high heat-dissipation, integrated in baffle. Pure aluminium wire voice coil. Neodymium magnet ring.
Midrange: Die-cast chassis. 15 cm one-piece moulded MSP polypropylene cone. 38 mm pure aluminium wire voice coil, wound on aluminium former.
Woofers: Die-cast chassis. (2) 20 cm one-piece moulded MSP polypropylene cone. 75 mm long throw pure aluminium wire voice coil, wound on Kapton.
Crossover: Thick glass fibre-reinforced PCB with extra copper thickness. Capacitors with low loss dielectricum. Zero compression resistors with thermal coupling to heatsink. Inductors wound on ¡°air cores¡±.
Cabinet: 20 mm MDF with internal MDF bracing and bituminous damping panels. Large 100 mm diameter vent with trumpet shape in both ends, vent plugs included. Available in different veneers, maple, cherry, rosewood, and black ash. Custom finishes upon request. Grille with magnetic lock system included. Spikes included. |
