Small size rooms: >30 watts Medium size rooms: >80 watts Large size rooms: -- watts
IEC Long Term Power Handling:
<100 watts
Impedance, Nominal:
4 ohms
Impedance, (20-200 Hz):
3.7 - 12.0 ohms
Impedance, (200-20 kHz):
3.6 - 7.77 ohms
Impedance, Phase Shift (20-200 Hz):
-36.3¡Æ - +29.4¡Æ
Impedance, Phase Shift (200-20 kHz):
-9.8¡Æ - +22.2¡Æ
Impedance, HF (200 kHz):
7.6 ohms
Frequency Response (+/- 3 dB):
80 Hz - 25 kHz
Resonance Frequency:
97 Hz
Internal Cabinet Volume:
2.4 litres
Bass Principle:
Closed Cabinet
Weight:
10.6 lbs. (4.8 kg)
Dimensions (W x H x L):
6.5¡± x 10.9¡± x 6.5¡± (165 x 277 x 166 mm)
Crossover:
2 way. The crossover is impedance corrected.
Crossover Frequencies:
2300 Hz
Crossover Slope:
12 dB/oct
Connection:
Gold plated binding posts (for spades and 4 mm plugs).
Magnetic Shielding (3 gauss) minimum distance from TV:
5.5¡± (14 cm)
Recommended Placing:
Wall, shelf, or stand.
Remarks:
Tweeter: 28 mm soft dome - technology from Esotar Magnetic fluid. Pure aluminium wire voice coil. Woofer: Die-cast chassis. 15 cm one-piece moulded MSP polypropylene cone. 75 mm long throw pure aluminium wire voice coil, wound on aluminium former.
Woofer: Die-cast chassis. 15 cm one-piece moulded MSP polypropylene cone. 75 mm long throw pure aluminium wire voice coil, wound on Kapton.
Crossover: Glass fibre PCB with extra copper thickness. Capacitors with low loss dielectricum. Zero compression resistors. Inductors wound on ¡°air cores¡±.
Cabinet: 16 mm MDF. Metal baffle sandwiched to the cabinet through a damping panel. Available in different veneers, palisander, maple and cherry. Custom finishes upon request. Grille with magnetic lock system included.
